Currently reading:
BG AR missing screw from fire
Discuss BG AR missing screw from fire in the Plumbing Jobs | The Job-board area at PlumbersForums.net
princegoose
Hi, going out to a job tomorrow. Old lady says BG have At Risked her Valor Fire as theres a screw missing. Her reply was, well its only BG who touch the fire so its your responsability.
Sounds about right to me.
Big question is, can anyone give any suggestions as to what screw missing could AR a fire, ive been trundeling throuch the MIs online but nothings shouting at me. Could be one i show the GS inspector when he comes out in a weeks time. :confused:
screw head on restrictor elbow maybe
details of screws here [DLMURL]http://www.valor.co.uk/valor/website.nsf/940%20Decadent,%20Adorn,%20Visage,%20Icon,%20Dream,%20Eternal,%20Obsession%20install%20and%20owner%20%285122722-02%29.pdf[/DLMURL]
know that fire well,could be burner locating screw,wire fixing kit screw or gas lever screw which i doubt its the later as fire would not work,dont forget to check aeration setting is correct this can get over looked,also this has a cast heavy facia screw missing from this could be perceived as ar but ott, this would be 2ba threaded 20 mm long
could be a early one that used coals only,when BAXI took over the aeration setting was made adjustable for coals/pebbles
ah yeah, all she gave me was valor BR622, so its an old one, unless other models has BR622 code as well, am i going along the right lines?
no worries pg and thanks hihowudoin for the pdf the 940 is a shed prone to microswitch problems causing the lot to shut down,so be careful with the yellow wires
ive caught up with you both, were you looking at the pdf??
thanks
so i dont need to check aeration setting?? tbh i wouldnt have known to :-(
thanks
no no need to check it or the yellow wire issue,just go trough it with all the usual tests and look for missing screws
Job done, BG service engineer couldnt get one of the fixing bolts off so couldnt check the flue. i was still there for 2 and half hours mind. for a set price service. poo. happy old lady though.
Reply to BG AR missing screw from fire in the Plumbing Jobs | The Job-board area at PlumbersForums.net
