Discuss Best thermostat location in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Also neck height no higher or lower. Is that meant to be right? Can't remember the reason why. But somebody said to me once 'where you would wear a scalf to keep you warm' and it stuck in my mind.
Is it just more to do with access then? I was lead to believe at the time it was kinda the height you wanted to monitor the temperature.1.5m off the floor unless it's for a disabled customer then set height that is best for them
Or the new TRV where you can control the temp in each room. But they are really priceyDepends on your property Dan zone the heating you can have time and tempreture control in each
But the times I'm too hot in the bedroom (not in the nice way) yet it's too cold in the living rooms etc is way too often.
What would i need to regulate the rooms better?
Reply to Best thermostat location in the Plumbing Jobs | The Job-board area at PlumbersForums.net
