Discuss Best replacement for this. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
armyash
Subscribed
Ive been sent this by a customer who has asked me to replace this.
What would be quickest replacement?
I'm guessing water heater the French one :D
Depends still get the main multi points
Yeah it's a water heater :)
I havent been to the property yet but the guy wants it done Saturday so wanted a heads up before I go.
Not many choices left on those ,”Main “do one that is ok ish , Vokeras is called the aquanox ( or something similar ) but needs electric so will have to be moved. Theres another manufacturer but cant remember name , somebody else may help
As above.
It’s a multipoint water heater by chaffetaux ( not spelt correctly!)
Only option for replacement needs electric so would need moving.
You could try eBay and see if there’s anything.
Looks like I'll be using a main multipoint. Just checked out the mi's. No electric needed. Moving the appliance is not an option.
Customer has been without hot water for 2 weeks due to being let down. I've said I can do but not until Saturday.
Reply to Best replacement for this. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, My current hot water system needs to be replaced. Anyone got any suggestions or can recommend any plumbers around Derrimut area that won't...
I have attached an image of the brass body within a tap. Having replaced a cartridge which has cured a leaking tap, I can see that there is a...
Hi guys. I'm trying to identify a toilet model before ordering a seat for a customer. I went to what used to be a Roca stockist (they no longer...
