Discuss Bent my TRV pin. It's not currently leaking, but could it come loose? in the USA area at PlumbersForums.net
Good morning!
I've had no heat in my attic bedroom for over 2 years - the rest of the radiators worked fine, but this one was a dead duck.
I watched some YouTube videos, and read through these forums, and decided to have a look at the TRV pin. Lo and behold it was stuck down!
I managed to free it and small amount of water came out. I put it back in and tried pushing it back down, but it's completely stuck sticking upwards! I tried to force it down by pressing on it, and the pin bent sideways under the pressure.
The good news is the radiator is now hot...
My question is, is it OK to leave the bent pin in there? I never adjust the thermostats, and the cap has secured it in place. I don't think it's leaking, but is there a danger it could pop out while it's like this?
Any advice would be gratefully received!
Hi, I am glad that you have managed to fix the radiator and have got a warm room!
Hopefully one of our members will be able to answer your query.
Reply to Bent my TRV pin. It's not currently leaking, but could it come loose? in the USA area at PlumbersForums.net
Hi I need some advice as this has been ongoing since august and nobody can find a problem but meantime water is damaging my walls. The lady...
Hello all, I have a WorcesterBosch Greenstar 42CDi classic combi, which is providing DHW fine, but not heating. Was working fine in spring...
This issue arose about a year ago. Does anyone have an idea why I occasionally hear (about once every hour or longer) a hammer related noise...
My kitchen radiator is filling with hot water despite my TRV being set to 0. It's blazing at maximum. This goes for the rad when I try two...
2K
Context for issue: Last winter the temperature switch on my boiler shorted somehow, the boiler was then running WAY too hot and ended up...
