Discuss Baxi duo tec combi 24 HE A Boiler de-aeration in the Central Heating Forum area at PlumbersForums.net
Hi everyone, I wanted to ask is there a function to remove air from a Baxi duo tec combi 24 HE A.
If there is can some one kindly tell me the procedure.
Looking online i found on newer baxi boilers that you turn the heating knob all the way back (12-oclock) anti-clockwise and then 2 quarter turns back and forth twice, is that correct?
Like on a Vaillant Boiler there is a P0 function to purge the air out.
put the boiler on low very low and leave it running for and hour, then turn the heat up a little ie, 50 leave for a hour,
then see how you go from there.
Reply to Baxi duo tec combi 24 HE A Boiler de-aeration in the Central Heating Forum area at PlumbersForums.net
