Discuss BAXI Combi Instant 105e pressure in the Central Heating Forum area at PlumbersForums.net
Can anyone give me clear instructions for repressurising / topping up a BAXI Combi Instant 105e? Please see attached photo. Levers should be at top in case it appears rotated. It's not my boiler so am unsure. Thanks!
Filling loop is the stainless steel loop the black knob on the inlet side is in the off position turn it so it starts to line up with direction of valve you will hear water go in!.
If there is a similar knob or screwdriver slot on other valve at other end of loop that needs to be open as well.
Thanks for taking the trouble. I think by my photos there are two black levers / knobs, one between the steel & copper pipe & one just before the copper pipe enters the boiler. Not at house at mo so will check for definite when there. If there are two, does it matter the order in which they're open & closed? Any idea what pressure I should fill to? Thanks again
Reply to BAXI Combi Instant 105e pressure in the Central Heating Forum area at PlumbersForums.net
I have a very strange issue with my BAXI 105e DHW. if i turn on the hot tap the pump starts and demand for DHW is shown, after a some seconds it...
Hi all. After some advice before I get some quotes. I have a 19 year old baxi 105e instant that needs replaced for something more efficient. I’m...
2K
Hello everyone, Baxi Ecoblue System boiler which was recently serviced just before Christmas. There has since been a constant but slow drip...
A
Hi, I have a combi-boiler system and while I did some plumbing many years ago I have never fitted a combi-boiler and am confused by this problem ...
Allan 1234
A
My Grant combi oil boiler is giving me quite a headache at the moment. When I returned home last Friday I'd no heating or hot water. An engineer...
