Discuss Baxi combi 105e, pilot keeps going on and off in the Plumbing Jobs | The Job-board area at PlumbersForums.net
K
Kelly Hillsden
Sorry this is long but i want to give as much details as possible.
I have a Baxi Combi 105e, when i run the hot water the red temp neons get to about 60 then the pilot go of for about 5 water comes through warm then lights up again and gets hot.
Also when running the central heating it does the same thing gets warm then pilot light goes out then occasionally the central heating fault light will flash but only once or twice then the pilot kicks back in again or when heating is on the temp lights go up and down and sometimes the pilot stays off and wont come back on
I have had a new divert valve fitted and a new diaphragm fitted.
When running the hot water you can see the pin going in and out of the diaphragm, also pin which comes out of the top of the diverter manifold comes out, but does not seem to retract straight away when water/heating is not on and sometimes the fan stays on and also come on one its own when not water running or heating.
I have had a look at the central heating sensor and it is not corroded, nor is the safety thermostat sensor.
Any idea what to replace as i was think of just replacing the following:
Central heating sensor
Safety Thermostat
DHW temperature sensor.
Failing that i was looking at getting a new PCB, but if you can give me a cheaper alternative that would be even better.
Any help would be greatly appreciated
Kelly.
We cannot and will not give advice on the installation or repair of boilers, cookers or ANY gas appliances for your own safety.
Please go to Gas Safe Register | Ensure your gas engineer is registered. or post a thread in the 'I'm looking for a plumber / gas engineer' section of these forums remembering to include your location. [DLMURL="http://www.ukplumbersforums.co.uk/im-looking-plumber-gas-engineer/"]I'm looking for a Plumber or Gas Engineer[/DLMURL]
If you are gsr please increase your post count to 10+ then send a PM (Private Message) with your gsr details to either Gas man - View Profile: gas man - Plumbing Forum | Plumbing Advice | Plumbers Forums | A forum for plumbers advice in the UK or Redsaw - View Profile: REDSAW - Plumbing Forum | Plumbing Advice | Plumbers Forums | A forum for plumbers advice in the UK who will check you and then give you access to the gsr private forum.
Providing gas-related advice to anybody who should not be touching gas and cannot prove their competence is unacceptable. We will take whatever action we deem appropriate to prevent such advice being given
Thank you.
UKPF TA's, Mods and Admin teams.
[DLMURL="http://www.co-gassafety.co.uk/deaths.html"]CO Gas Safety[/DLMURL]
http://www.ukplumbersforums.co.uk/central-heating-forum/42241-notice-gas-safety-related-advice.html
Reply to Baxi combi 105e, pilot keeps going on and off in the Plumbing Jobs | The Job-board area at PlumbersForums.net
