Discuss Baxi Bermuda 45 back boiler not working in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi All
New to this and a little green around Gas boilers.. So, a house I’m in possession of has an old and trusty Baxi Bermuda 45 back boiler which worked perfectly fine until I isolated the gas supply from the meter box..
After a couple of months and with the weather getting colder, I’ve went to turn it all back on and….nothing.. tried pressing the button and starter multiple times…nothing..The actual gas fire works fine, but the boiler does not appear to be firing…
is there something wrong or am I not doing something right..?
thanks
you have to keep the knob pressed in all the time then press the (starter) it some times takes a few (clicks) to get it to light,
wait then 10 to 15 secs then let go of the knob
.see how that goes.
How to light a pilot light!
Press in the grey button that is about the size of a 10p coin.
Hit the orange sparker button about half a dozen times then listen for something burning (hard to explain) as to actually see the pilot on a 45 you need to be a contortionist with a neck like a giraffe.
Keep holding the grey button for at least 30 seconds (sometimes patience is a virtue) then release slowly.
If it doesn't work after a couple of tries phone a friend with a gas ticket as it needs a part replacing.
Reply to Baxi Bermuda 45 back boiler not working in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
J
Hi all, I am a plumber but I do not carry out works to boilers as the majority of my is bathrooms so I am not gas safe. I have completed a...
Heating and hot water is not working. Plenty of heating oil. I have replaced batteries in thermostat and it seems to be working ok, showing flame...
Hello everyone, Baxi Ecoblue System boiler which was recently serviced just before Christmas. There has since been a constant but slow drip...
Hi I have a Glow-worm back boiler which is giving me grief (I would have upgraded it by now but its a listed building and there's issues with...
Hi My grandmothers property has a back boiler heated by a solid fuel appliance using coal. Yes, I know. She’s stubborn! Unfortunately the...
2K
