Discuss Bathroom radiators stopped working in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Y1D
Hi there
I’ve had to have a new heat exchanger and air valve installed into my boiler which is now working well. The only problem is since then neither of my 2 bathroom radiators come on. They both always used to come on when the hot water was on, as well as when the heating was on which was nice to have nice warm rooms in the morning.
I’ve tried to bleed both but water comes out straight away so it’s not air, and all the other radiators work fine.
Any ideas what the issue could be and can I resolve it or will I need the plumber back again?
Thanks.
do they warm up with the heating on?
Hi, thanks for the reply - no, they’re permanently cold.
did they used to come on with the rest of the heating?
Yep, they used to come on when only the hot water was on, as well as when the central heating was on. It was useful as it warmed the room as well as dried the towels. Now they don’t work at all.
could be air locked
turn the heating on
and if you have trvs on all / most of the other rads turn them off
should sort you out and once the rails become warm turn all the other rads back to normal / what they were set at
and then bleed the towel rails
could be air locked
turn the heating on
Thanks will try that in morning as the lad has just gone to bed. Will report back - thanks
Still no joy. The plumber did say there was air in the system and it had no where to go.... Guess it went into the bathroom radiator pipes.
The feed pipes aren't even getting warm so I guess ill have to get someone else out to take a look.
Hot water wasn't on when you tried my fix was it ?
No. The pipes into the radiators aren’t even getting warm. I’ve removed some aif from another radiator and checked all, but as soon as I loosen the nut water comes out and no air.
What about turning all the trvs off did you do that ?
Not sure what that is.... I turned off all the other radiators by their thermostat if that’s what you mean?
Yea
Sounds like you might need him back after all
Reply to Bathroom radiators stopped working in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Oil boiler (now~15 years old) unvented system with 17 radiators. We moved in 5 years ago and I had to keep bleeding the same radiator. The bleed gas could be burned with a blue flame and the water was acidic (pH 5.5). Since then system has been chemically flushed (it was not too bad) and the...
Hi All, In Dec 2023 I had my annual boiler service and asked the plumber to change 2 radiator valves as the radiator in the toilet downstairs was not working. He changed both valves and still the radiator was not working. He put some chemicals in and said it should break up anything that is...
My towel rail is not electric but separate to central heating and has been working consistently but since the 2 port valve was replaced on Monday because the radiators were not working it has stopped working, if I go into the loft and press the flame button on and off it seems to come back to...
Hi so I changed a towel radiator in bathroom from a normal radiator. I bunged the f&e tank and vent pipe , drained about a pint of water out the pipes. Altered the pipes to the new rad. Then removed the bungs. Gone to bleed the radiator it filled slightly now no air is coming out. I've...
When I turn on our CH there's a lot of noise from one specific part of the system - the pipes on the landing, and one radiator. It sounds like air, and the landing radiator needs bleeding regularly (about once a month), even though it isn't the highest point in the system. The two upright rads...
1K
