Discuss Bath mixer or immersion heater in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi
Bath mixer tap is running too hot in shower, almost scalding.
Other taps seem mostly good temperature. However there is immersion heater in flat.
How do I differentiate whether element stat or mixer tap is failing.
is the tap thermostatic? what temperature is the thermostat set to on the cylinder? oh and welcome to the forums
I would say if all other outlets are fine then there is a fault with the tap maybe a restriction on the cold side not allowing a decent mix
Reply to Bath mixer or immersion heater in the Plumbing Jobs | The Job-board area at PlumbersForums.net
