Discuss band b boilers faults to look out for in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Billy Bob Bob
one to watch out for
had a flame failure fault on a main 24 he(same boiler as a baxi 80 he or performa 24 he)
basically it was giving the classic aps died symptoms but the aps tested fine,the venturie was spotless,the fan speed was good,i knew it was not the flue at fault i fitted it in 2007, but its right on the 4 mtr limit for this flue so despite the fan doing everything it should with no obvious signs of being knackered i replaced it,this cured the fault so worth remembering band b condensing boilers cant flue as far as there SE predecessors any weakness in the fan it causes this fault
Also had problems with the gas side of secondary heat exchangers clogging with muck causing the same problems.
Reply to band b boilers faults to look out for in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello, My mum has a Worcester Greenstar HE30 boiler (15+ years old). Since its last service (and possibly coincidentally) it has been making a...
2K
  • Locked
Morning all, We inherited a c.2007 Heatline Compact boiler when we moved into our house. On Friday the boiler developed an air pressure fault. I...
1K
Hello, from South Devon. Firstly - I'm not a Gas Safe RGI. I'm considering my options to replace a 23 year old |Ideal Classic FanFare 50,000 kw...
3K
  • Locked
i have been trying to fix a performa 24 eco he, flame failure fault. (before you ask, yes i am, 546451) originally there was no spark, replaced...
4K
Dotty
  • Locked
Went to this on Friday last week, boiler going to flame failure and no further on both CH and DHW. Fan running, No ignition, checked APS manually...
