Discuss back boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
X
xtremeo
got my cenwat exam next month, revising may get a back boiler, where do you cpa one draft diverter. with no fire or do you not cpa, just spillage and flue flow.
hi thanks for reply, boiler is old and before cpa, MI just state splillage
be interesting trying to do a fga test on the boiler with a fire fitted, and with the fire off dam nigh impossible to reach through to the divertor on most so follow MIs as normal, never had to cpa a bbu on my acs yet
You won't get a bbu to analise, maybe an open flued floor stander with a hole drilled in the flue. The results will surprise you.
Reply to back boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I have just looked back through the regs this seems to have changed and it isn't mentioned now. It now mentions if at high level it should be discharged...
