Discuss b,b,u back boiler heating only works when hw is asked for in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
jamia
there are no cylimder stat or room stat , just a control that slides over for hw or ch the system is gravity hw and pumped ch when i ask for hw the pump kicks in how can i wire a stat in and get ch only when asked for
I'd go read your other thread if I were you.
Or is this mob culture?
Reply to b,b,u back boiler heating only works when hw is asked for in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All, Hope somebody can help :) I have a vented HW system with a pressurised Ch system but got bit of a annoying issue, when the hot water...
Baxi 600 central heating is set at minimum the radiator symbol on the boiler is flashing. (asking for heat .fan is still running ) this is like...
Hello, my HW is taking longer than expected to heat up and it's getting worse. I can go 10-40 degs after 1.5 hours of only heating HW, whereas I...
Hi, I am replacing our 11 year old boiler (due to H.Ex. leak) with a new one. This is in a "sealed" system with red expansion vessel in airig...
M
Hello, We’ve recently moved into a fairly old, fairly big detached house (i.e. fairly draughty, but not too bad by any means) with a fairly new...
MartinPod81
M
