Discuss Baxi 600 asking for heat in the Central Heating Forum area at PlumbersForums.net
Baxi 600
central heating is set at minimum
the radiator symbol on the boiler is flashing. (asking for heat .fan is still running )
this is like this all day
is this correct before I call out engineer
there are no other controls ie time lock or room stat on system
There will be a room stat any chance of a picture of the whole boiler and pipework?
There are no other controls fitted
boiler is wired to a fused spur
Well that’s no good and not upto regs it needs a thermostat or some control
Yes it will constantly run
Yes I had an ancient boiler set up like that when we moved into our house, zero controls not even a timer nor a room stat.
We basically just switched it on at the wall when we wanted heat and off when not - not compliant to current regs of course . But you can heat your house/water like this. Ours has now been replaced following extension etc, but we used it like that for 3 or 4 years.
Reply to Baxi 600 asking for heat in the Central Heating Forum area at PlumbersForums.net
PSxxxxxx
