Discuss Ariston boiler cuts off when hot water boosts in the Central Heating Forum area at PlumbersForums.net
Hello we are having issues with our Ariston gas boiler, it’s not a combo boiler, we have a separate hot tank. The boiler trips off when the hot water boosts. We store pans in the cupboard under the boiler and I suspect we have knocked a valve. I have taken pictures, would anyone be able to tell me if the valves are positioned correctly?
Sorry forgot to attach them….I’m stressing out 🤦🏻‍♀️
Difficult to say, but one filling valve looks off. Have a look in the cylinder cupboard at the motorised valve(s) for water egress from spindle and ingress into the valves.
It’s possible it’s overheating on hot water, so could just be a fault somewhere. On the zone valve in the cylinder cupboard, they’ll be a lever , select hot water on the programmer, and check out the lever, if there’s resistance then the valve isn’t opening up as it should. This valve will be where the pipes enter the cylinder.
Reply to Ariston boiler cuts off when hot water boosts in the Central Heating Forum area at PlumbersForums.net
