Discuss Are metric 28mm olives fine on imperial 1" copper? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
WaterTight
Subscribed
And used with 28mm compression?
Yes. They are close enough & the old imperial 1" pipe is very fractionally wider, so that will mean the 28mm olive will be a nice tight fit.
One thing I should mention is you might find the modern brass nuts on the new fitting will be very tight in the 1" pipe. Especially cheap fittings. Conex are nice slack nuts
Reply to Are metric 28mm olives fine on imperial 1" copper? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I am in process of replacing an existing sink with a new stainless steel one. The existing tap is plumbed directly to copper which means that it...
Hi all, this is probably a daft question but I need to run my cold feed from one side of my wall mounted boiler to the other. Running it beneath...
