Discuss amateur....any help appreciated-combi and rennai water heater in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi there
I wondered if you could help? I'm currently piping up the central heating for my Mum and she's already got the combi boiler a while ago which is an ideal vogue 40kw (so she is out of time to return).
We're on a very limited budget as its a big renovation which is why we're doing the piping ourselves with the intention to get a professional to do the boiler connection/ gas and commission. My dad's a retired gas man with 2 bad knees (recently replaced) so hes been advising/ teaching along the way but hes away so I've tried to scour the internet for a solution to this problem.
My mum has a guest side of the house with 2 en-suite bathrooms which I guess will be used intermittently and in the loft she has the intention of making a self contained flat with bath/ kitchen which will be used more frequently.  I realised the combi will not cope with hot water for all these rooms + my mums own bathroom/ kitchen so I'm thinking of piping up for a rennai water heater to provide the hot water demand for the guest rooms/ loft.
I can see the heater has a 22mm cold inlet/ 22mm gas inlet and hot outlet but I have some Q:
can the 22mm cold inlet be branched before entering (I guess I'm asking this for both the combi and water heater)?? This is the scenario......
The cold has got to come from the mains, travel about 3m and then be branched in 22mm for main bathroom, ......travel about another 3m then a T- .....one branch travel about 1m and then enter the combi and the second branch travel about 1.5m then a T.....one branch will go to supply cold to ensuites/kitchens etc....and the final branch will enter the water heater?
do the inlets into the water heater have to be in copper or be in barrier pipe?
I would really appreciate any help-you really helped me before with my cast iron radiator problem :/ don't you just love old houses!
Elli :)
From what I can gather, you will end up with 4 bathrooms and 3 or 4 kitchens.
Are you sure that the incoming water mains are able to cope with the possibility of say 3 showers running at one time.
Whats the incoming mains pressure and flow rate.
Too many variables pop into my head when reading your post to give you any accurate advice.
40 kW combi boiler and rinnai water heater + other gas appliances - thinking you will need around 400 mj/h gas supply. Is there adequate gas supply available. Have the gas pipes been sized correctly for the appliances to work?
Don't take offence, but I think you're completely out of your depth on this one.
thanks for the reply/information. Mains pressure was not something I had considered. It will be:
1 bath/ kitchen running off the combi
2 ensuite (intermittent use), 1 bath, kitchenette running off water heater
All the gas pipes/ flow return have been run initially in 28mm dropping in size towards the end of each run.
I have decided to do a continuous run from the mains to the combi/ water heater and branch later in the run. Probably we are out of our depth but we have been since we started this renovation :S
Unfortunately needs must and doing our best on a limited budget and always seeking advice and getting qualified sign off/ building control-just need to get mums side done so she can move out of our side-for my sanity more than anything :)
thanks again
I`m thinking you are best talking to whoever you have lined up to sign it off tbh.
Just a tip you can't install any pipe that carries gas unless your gas safe
Sorry to say
Sorry to say
Think he has done it already ! Water supply could be a problem, this property should have been converted to unvented hot water system. Flat needs its own independent system if its going to be rented, and he needs to look at how it's going to be controlled, would be better to sell the combi and get a proper system installed
I think Elli :smiley2: might be a "she".
Have you asked your dad these questions?
Surely he would know about flow rates etc
right answer to first question
yes the can but all depends on incoming pressure and flow rates (whats your incoming supply)
but if your water heater requires you to have a pressure reducing valve before it enters the heater run any balanced outlets / showers after this (so the water is the same pressure as the hot)
and copper would be the best bet
just a question where are you located?
Reply to amateur....any help appreciated-combi and rennai water heater in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have just moved into a late 1990s new-build house with a small bore (about 1/2" OD pipes) gas fired boiler central heating system. All the...
Been to a site today and every sink has a 15l water heater underneath on each of the prv's discharge after the tundish their is only about 200mm...
Hello, I have quite low flow rate for my electric shower (a piddling 5L/min), and would like some tips or advice about how to solve or find the...
Essaboy
E
Hi all, My customer needs a new water heater/boiler - preferably electric. (Getting the gas pipe through to the desired location is a bit of a...
Hi all, thanks for adding me. My Veissmann v50 combi gas boiler has recently started to supply only lukewarm water to the bathroom above it. This...
