Discuss Alpha boilers your opinions please in the Plumbing Jobs | The Job-board area at PlumbersForums.net
king of pipes
Subscribed
Hi guys there does not seem to be much talk about alpha boilers on the forum good or bad i service a few and am in the process of fitting a couple intec 2c s in 2 flats they seem ok alot worse out there i am off to the factory in may to have a look around and maybe pick up some info would be interesting to know your opinions regards kop.
Not good, they need setting up and user / engy controls arnt easy to use
Intec 35se worse boiler out there
One year old maxed out my fga on ppm (15000+) got it down to 93 after just setting up the gas valve
Took me two hours to do
I only work on the older ones now, don't touch the newer versions and haven't fitted an Alpha for about 4 years,
Have replaced about 200 with different makes in the last 4 years!
Never fitted one and after getting a charge for ÂŁ11 when stuck waiting for technical to answer ...... I never will !!!
Yeh the census seems to be not that good, im with the others , ive worked on quite a few , servicing and fixing but never installed , although they wouldnt be the worst choice just nowhere near the best and dont think theyre all that cheap either ,
Ideal prices around the 800 mark
I replaced a 20 year old Aphla combi last winter, I think thats a once in a life time thing
well that didn't go down to well , guess I will stick with what I know cheers guys have a great Easter cheers kop
  • Funny
Reactions: Dan
got 2 for ÂŁ499 each + vat that's why there going in theses flats all the best kop
That's a good price do you mind me asking where from local or Internet ?
my local plumbcity branch shaun had a job lot to get rid of , so got 3 one with a vertical flue ÂŁ515 + vat.
Here you go guys not wired as yet alpha eco 2 28kw not the best but certainly not the worst cheers kop
Reactions: Dan
Fyi your condense connection will leak
Mac overflow compression coupling
Also read up on how to get them in low and high fire modes :D
Going on a factory vist on the 9th of may so will pick up a few tips then wasnt to keen on the condense arrangement 25mm to 19 mm reducer out of a rubber 45 0 elbow they supply , but it had a proper metal flue and elbow and all went in ok cheers chaps kop
Replaced the one I repaired with a viessman condense hose one jub clip either end and your golden
Did you put the included zip tie on the rubber to trap connection?
Love the bends
  • Agree
Reactions: Dan
Reply to Alpha boilers your opinions please in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I am looking for some basic advice please My house is on two floors, approx 240m2 and a spacious loft with good headroom and access. Glow Worm...
Hi. I'm having some issues with my boiler / central heating and have enlisted a local 'Combi Heating Specialist' to sort it out but he seems to be...
3K
Context for issue: Last winter the temperature switch on my boiler shorted somehow, the boiler was then running WAY too hot and ended up...
So I bought my first flat recently (am in UK) and in a bit of a pickle as the bathroom has turned up lots of problems that weren't picked up by...
B
Context for issue: I'd like to start by saying I'd rather not read 100 "Hire a professional comments", I will do that when/if it comes to it, but...
Butchy10
B
