Discuss After some advice on a Worcester Bosch 38cdi in the Plumbing Jobs | The Job-board area at PlumbersForums.net
hellfire
Just had a new customer having a problem with her boiler Worcester 38cdi showing fault code C6 boiler installed 2012 December saying it's out of warranty not a Worcester man myself so any advice would be very helpful before i pop round to have a look.
Fan speed too low / not running
Thanks for the quick reply is it straightforward fan swap just getting in to fault finding on boilers what's the next steps I should be taking. Once again thanks for your time
Wow that font is extreme pal!! :D
Have to confirm its the fan first and not a control problem eg pcb etc
Follow the fault line diagram in the back of the mis
C6 is a fan fault, if you are just getting into boiler repairs , get multi-meter ready , ring Worcester Tec & they will talk you through what you need to do, have phone on hands free so that you can use probes when testing
Im sure memory serves me right it should be 240 across black n purple on the wb fan cdi, very easy to replace if its the fan, and theyre common for going after a period of time,
Reply to After some advice on a Worcester Bosch 38cdi in the Plumbing Jobs | The Job-board area at PlumbersForums.net
PSxxxxxx
