Discuss Advice please chaps. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
mutley racers
Subscribed
I am at a Worcester 24i rsf which they have asked me to service. Now the boiler is a combi and it's not connected to the hot water supply and only has 2 radiators attached. It lights for 5 minutes and then off. I am not able to get a gas rate or burner pressure due to the lack of heating load and hot water. I am not sure if this appliance has ever been commissioned properly due to the above reasons. I am inclined to At Risk it but as it has been in a while should I just leave it. Cheers chaps
Can you not attach a bit of copper and hose to the hot outlet to at least give you some chance to service it?
All pipework was boxed in right up to the bottom of the boiler so not easy access to attach a bit of pipe and I had to be at another job. I did say I can connect it up but he said he would rather not as he might be extending the building soon.
I can only think its an AR if it has this fault and you have no way to test it and as you said it most like never got commissioned properly.
My view would be ID as you pointed out that you do not think it has been commissioned (take it there is no paperwork?)also as you have no way to test it, therefore not able to prove it safe for continued use?
may be talking rubbish as usual but that's the way I look at it.
I came across a boiler which I couldn't get the case off due to boxing in on a gas safety certificate, so couldn't comeplete regulation 26:9 and gas safe tech told me to AR it
It can't be serviced/ tested as per Manufacturer instructions so you at very lest have to leave AR. Basic 26(9) checks are out window.
No service mode and all readings are taken on hot water.
Unless you know the appliance is operating dangerously it is only ever going be AR.
Reply to Advice please chaps. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A close relative has moved to a new property and there is a small ground floor toilet room with a non working extractor fan fitted to the ceiling...
We have a pumped shower with a thermostatically controlled mixer valve. My wife complains that when she is having a long shower (hair wash etc)...
Hoping someone can please help. I have an intermittent fault with my electric hot water. I have an older style electric hot water service that...
I am seeking some advice on how to seal up my sump pit. I currently get condensation on the walls and floor around the pit, and in the past there...
