Discuss Add flexible valve hose to flush valve pipe in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hello
I need to change my flush valve. Can I cut the pipe (photo attached) going in and add flexible hose with a valve? As can’t currently get to the valve as behind the waste pipe.
Thank you for any help
The front panel should just lift up eg cut the silicon around the pan and the whole front panel will just pull up
You should be able to get to the valve then if you can’t use a compression cap end eg just the male bit onto the swivel / where the ball valve connector is
Reply to Add flexible valve hose to flush valve pipe in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
