- Messages
- 10,855
Morning all
would you agree with my thinking here. Not a perfect solution but the only one I can think of.
been asked to try and improve hot water flow In a top floor flat.
All hot comes from direct fortic cylinder on same level as bath, basin and kitchen sink so virtually no head.
In addition they also have what I believe is a negative head electric shower that just pumps from the cylinder.
My thoughts are add a pressure reducing valve to the cold feed to the other fittings and then add a single impeller pump to the hot to give pumped hot at all outlets? And then replace electric shower with a normal thermostatic bar mixer?
i know this isn't an ideal solution as you won't have perfectly balanced hot and cold but I'm struggling to think of an alternative.
Cheers
matt
Cheers
matt
