Discuss 365 Drills in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Yep saw that
Got removed from here and Williams pretty quick
it's disgusting, needs his head checking
I missed it.
Met the bloke and he seemed decent enough.
Makes you wonder what goes on in some folks heads.
Did he get found guilty in court?
And what? If any was the sentence?
I've altered your quote Shaun, I'm sure that's what you meant to type
(obviously if he is guilty)
Obviously but that would be too quick, things can get creative especially if you have a bit of time always fun with the old oxy and acet ;)
Reply to 365 Drills in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I have just looked back through the regs this seems to have changed and it isn't mentioned now. It now mentions if at high level it should be discharged...
  • Article
A Plumber Who Worked Illegally Gets A Suspended Sentence After Falsely Claiming To Be Gas Safe Registered. A Plumber in Herefordshire was prosecuted after Hereford Trading Standards Team found that he was falsely claiming to be on the Gas Safe Register when he was not, putting members of the...
