Discuss 3 year old new build flat - Powerflush required?? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all - looking for some quick advice and all opinions welcomed!
Question: Is it really possible for a 3 year old new build flat Ideal Combi 35 to have "Multiple component failure due to poor water quality - drain down & powerflush required to inhibit future related issues, which are now unlikely to be covered under T&Cs"? The radiators and boiler and pipes etc were all brand new when the flat was built in a large complex 3 years ago and it hasn't been touched by anyone but Scottish Gas on their contract.
The recommendation is a £700 powerflush for a 3 year old system. The suggestion is that the water has too much chemical in it and that has caused blockages and issues. When the boiler is working, it heats the water and the radiators fine so any blockages don't seem to be in the radiators or pipework but potentially could be in the smaller pipes that feed the sensors of the boiler? To be clear, just feeding the boiler more water pressure doesn't fix the issue.
The history is something like this:
2014 - collected keys of new flat
Jan 2016 - F1 error. Low Water Pressure switch wiring looks incorrect. Fixed
Apr 2016 - Cleaned out blockage leading to LWP
Jul 2016 - Blockage and sensor fault. Replaced PCB
1 Jul 2017 - F1 error. Drained boiler. Checked LWP. Re-charged expansion tank. Boiler checked out okay
11 Jul 2017 - F1 error. Replaced Low Pressure Warning switch
20 Jul 2017 - F1 error again.. seeking advice from UKPLUMBERSFORUM!
It is hard to believe such a new system needs a full on powerflush to fix it. My experience is a powerflush takes hours and is for really bringing to life an old tired heating system and radiators in a house that has had rust in the radiators etc. I'd welcome any views or questions I should ask.
Thanks - Steven RW
Do you have a water softener? If so, draining and refilling withoutnbypassing that will destroy your boiler. I have also come across Glowworm boiler of just a few years old that kept getting blockages (the way they are designed meant a powerflush didn't cure it). Good luck though.
Sounds like your system was losing pressure constantly. This can introduce air and this can form blockages.
Personally, I think it won't need a clean, just a system filter and cure the loss of pressure issue.
dirt could be caused with constant topping up with fresh water. should find and fix problem which causing pressure drop, could be prv or leak somewhere. as suggested, magnetic filter close to boiler would be good. were these repairs done under warranty?
Reply to 3 year old new build flat - Powerflush required?? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
My daughter bought her first home and was hoping to convert to gas but its not available in the area, so thinking a boiler upgrade is the better...
Got up on Wednesday morning no hot water, (only cold water coming out of hot tap). Checked boiler, it had zero pressure and F1 fault showing. So I...
My Grant combi oil boiler is giving me quite a headache at the moment. When I returned home last Friday I'd no heating or hot water. An engineer...
We live in a 1980s four-bedroom detached house. The time has come for new central heating. The current system is a mild revision of the original...
2K
M
Hello, We’ve recently moved into a fairly old, fairly big detached house (i.e. fairly draughty, but not too bad by any means) with a fairly new...
MartinPod81
M
