Discuss 3 T rule hot water cylinder in the Plumbing Jobs | The Job-board area at PlumbersForums.net
O
Old Account
Hi I was wondering what does the 3 T rule mean when you install a hot water cylinder ? I'm guessing it has something to do with the pump : I mean where the pump has to be installed.
Looking forward for an answer as I have never heard about it before.
regards ronny
its not 3 t,the rule is last t piece on the return to go back to the boiler,that way rads wont warm up in other words no returns to rads dhw only on the last t back to the boiler
Aight, appreciate mate thanks a lot.
Was just curious as I heard so often 3 T rule.
Reply to 3 T rule hot water cylinder in the Plumbing Jobs | The Job-board area at PlumbersForums.net
