M
monks
I turned my heating on for the first time this year and found that although the hot water is OK, there is no heating. The boiler doesn't kick in when I turn up the thermostat.
I checked the zone valve switch which slipped so I changed it. However I noticed that the spindle which operates the brass valve only turns a tiny bit. How much should it turn? It doesn't seem to turn enough to me, only a fraction of an inch. I tried a spanner on it to see if it was stuck but it moves freely and stops like it's come to the end of its travel. Another thing is when I do turn it it bangs both ways. Also the pump seems to be pumping OK.
Anyway, the boiler still doesn't kick in. Any ideas? (The valve is the new type which has just two screws)
Thanks in advance.
Thanks in advance.
