Discuss 2 way 2 zone valve question. in the Plumbing Zone area at PlumbersForums.net
J
Jhonesy
Hi I have a honeywell programmer which does 10 min cycles but with the zone valve fitted it is closed during a 4.5 min long pump only cycle. Is there a way to stop this and only close when pump stops. It is open during heat and pump part but you can gradually loose a warm rad with it not pumping the water round enough when warm.
Reply to 2 way 2 zone valve question. in the Plumbing Zone area at PlumbersForums.net
Hi, Can anyone advise as to why the cold water to my bathroom keeps airlocking? This originally happened about 12 months ago and has happened 3-4 times since. Itā€™s an upstairs bathroom, fed from a tank in the attic. The tank is about 8 Meters away and feeds a bath, sink and toilet. The tank...
Hi. I need a new toilet supply line but donā€™t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic nut about the same size as the one going into the cistern but has a different thread. Attached is a photo. Can you advise. Thanks.
