Discuss 3 branch soil fittings in the Plumbing Jobs | The Job-board area at PlumbersForums.net
mutley racers
Subscribed
Are there any? As in left, right and centre.Or not, as you are not allowed to connect toilets opposite each other due to crossflow? I hope that makes sense. Basically, i have a ladies toilets to plumb in and the soil pipe comes in right at the centre of where the toilets will be. So two to the left and two to the right?
Cheers fellers
Thanks tamz, I think you have told me about these before. But, if i use them, is there a way to prevent against crossflow
Do you mean like this?
Polypipe SU420
OK, I have seen corner tees, and double branches, but I must confess I haven't seen one with another sideways input. Not above ground, anyway.
Marley, polypipe and the usual suspects all do them Ray.
No they don't. I should read before i type :smile:
New posts
Reply to 3 branch soil fittings in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi bit of a weird issue, I installed a grohe bathroom tap successfully 2 months ago bought from screwfix. Last week the right hand hot tap makes...
Hi, I have an old steel water mains pipe (approx 45mm) that I need to connect to a new pehd water mains (25mm). I can't get at it to create a new...
