Discuss 2 cold feeds to indirect hot water tank in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi, I am reinstating an indirect hot water tank and have 2 cold water feeds coming into it from the same supply. One of the feeds has a float valve but what ever was on the other has been removed. Why would there be 2 feeds to the top of the tank? Can I blank one off and just use the float valve to fill? Tank is a RCM group copperform tank, about 20 years old.
Feed on the left had the float valve attached, feed on the right must have had something removed. Third picture was something floating in the tank, I assume its off what ever was on the right hand side
Reply to 2 cold feeds to indirect hot water tank in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
For reasons that I won't go into. Is it possible to control the water flow to a cold water header tank without having a ballcock in the header...
Hello, and thanks for taking the time to read. I'm trying to work out if the idea I have is practical? The water pressure in my newly renovated...
We have hot water, tank for hot water why is the hot water boiling hot from tap,and shower, We are on a schedule for hot water via our hive app...
This unit is located in France where they use diesel not kerosene. The feed from the underground tank is not getting through to the boiler. The...
First post as I can not figure this one out. I have a hot water boiler heating system, gas fired, with an HTP SuperStor indirect hot water tank...
