Discuss 16mm prowarm pipe popping out of procrate on bends in the Water Underfloor Heating Advice area at PlumbersForums.net
Hi All,
I’m installing an ufh system using procrate and 16mm ufh pipe. The procrate is laid on top of insulation but I’m finding that at each bend and return the pipe is either pulling out of the procrate or the procrate is lifing up. What am I doing wrong? This is the 3rd system I’ve installed but the first using the crate system and this size of pipe. I thought the whole point of the crate was to avoid having to use clips.
:D gaffa tape helps on the bends to hold the bend down
Reply to 16mm prowarm pipe popping out of procrate on bends in the Water Underfloor Heating Advice area at PlumbersForums.net
