A
Alfie
I have an old stop tap which when I try to connect 15mm pipe to it the compression nut is too big. I cant use a new compression nut because the thread is different - imperial. A normal 15mm olive doesn't compress properly. I suspect I need a tapered olive - anyone know where I can get one from?
I've used a normal olive and PTFE for now but not sure it'll last.
thanks
thanks
