Discuss World Heat unvented Cylinder question in the Gas Engineers Forum area at PlumbersForums.net
Hi guys
I am having my current cylinder replaced with a World Heat superflow indirect cylinde as im upgrading to solar thermal via a grant. I asked the supplier if they are replacing the immersion heating thermostat and the thermostat thats connects to the boiler and I was told if I want that I would have to pay for these , my question is dont these thermostats come with the cylinder as standard, especially the immersion heating element and thermostat?
thanks
What do you mean by immersion heating thermostat? I ask because I find it odd that you’d ask the installer if they are replacing it on a new cylinder, as most new cylinders should come with an immersion and stat preinstalled.
Do you have some sort of external immersion controller that you’re confusing for a “immersion stat”?
If replacing a hot water cylinder, the job wouldn’t come with a new boiler stat. Or do you mean the cylinder stat that controls the boiler/indirect heat source? If so, yes they typically come with them preinstalled.
Like I said, it an odd question so I assume there is a miscommunication between the installer/yourself.
A "normal" twin coil cylinder that is designed for Gas/oil, solar and electric heating will have the solar coil in the bottom 1/3rd or so of the cylinder with a thermostatic dry pocket pre installed just above this (solar) coil, it may also then have another dry pocket pre installed ~ 1/3rd the way up this gas/oil fired coil or you may just have to use a strap on cylinder thermostat to operate the cylinder zone valve., I specified the dry pocket for mine as I utilize the solar controller to also control the cylinder zone valve via a PT1000 sensor in this pocket. It will also generally have a top mounted tapping for a conventional single or dual electric immersion which comes with its own thermostat&pocket but you supply/install the immersion yourself.
It is very important that the solar thermostatic pocket comes pre installed.
Reply to World Heat unvented Cylinder question in the Gas Engineers Forum area at PlumbersForums.net
Hi guys. I'm trying to identify a toilet model before ordering a seat for a customer. I went to what used to be a Roca stockist (they no longer...
