Discuss Worcester Greenstar 24Ri Condensing Natural Gas Boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Yes there is a LPG conversion details in the manual. Or buy the LPG ready boiler
do you need a conversion kit or is it a adjusting a gas valve type??? just thinking if it would be expensive to change it to lpg or jest get a lpg one
so there is no way the fitter could convert it?
The conversion kit consists of a sticker, a code plug which plugs into motherboard, that tells boiler it's now LPG, alters fan speed, ignition attempts reduced from 5 on NG TO 3 on LPG, and few other settings, then the gas valve if a sit valve can be tuned via FGA TO LPG co2 settings
Reply to Worcester Greenstar 24Ri Condensing Natural Gas Boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Article
A Plumber Who Worked Illegally Gets A Suspended Sentence After Falsely Claiming To Be Gas Safe Registered. A Plumber in Herefordshire was...
Hi all, this is probably a daft question but I need to run my cold feed from one side of my wall mounted boiler to the other. Running it beneath...
I have an ideal vogue max S18 boiler and I’m considering fitting auto balancing TRVs, my question relates to the boilers pump. I see a boiler...
