Discuss Worcester Bosch 32CDI . lots of air in Rads but no drop in pressure? please help in the Central Heating Forum area at PlumbersForums.net
Hi, i hope you can shed some light on this , Combi Boiler is located in the loft and was installed March 2020 on existing pipe work/ radiators , i topped up (2) radiators up stairs in October 20 it took a lot of water!
Boiler pressure is set to 1.5 bar (cold resting) and never drops. But found a lot of air in rads (3) upstairs , during the service on Saturday,asked the heating engineer about it and he said it took a lot of water to top up. said i must be a leak!. But to my thinking if i have a leak the pressure would drop? .
Hope someone can help me out here and thanks for your time Regards Rich
I'm assuming it's a sealed CH system.
After a replacement boiler is installed it is quite normal to find some 'air' in the system that needs bleeding. This is a combination of disolved air in the fresh water that was used to refill the system coming out of solution and hydrogen evolving as the passivating layer forms on new pipework, etc.
As long as you had the correct dose of decent quality inhibitor added to the water at the time the boiler was installed it is too soon to draw any firm conclusions. Just bleed the radiators, make a note of the pressure when the system is 'cold', and see what happens over the next month or two.
Many Thanks for the advice ,
Sealed system yes
The pressure when cold is 1.5 bar always and does not go down,
it,s been 11 months since the install and i would a thought all the air would have be removed by now
The inhibitor installed is sentinel.
The filter was very clean according to the engineer.
Am i right about the pressure would have dropped if the system was leaking causing a lot of air in the 3 radiators?
Thanks again
Reply to Worcester Bosch 32CDI . lots of air in Rads but no drop in pressure? please help in the Central Heating Forum area at PlumbersForums.net
W
My Worcester Combi Boiler is not working, instead the display flashes on and off repeatedly, as shown in <a href=" View...
Hey guys in the know. I have paid for a heating and plumbing contract and had to pay my excess 3 times for the same thing still not fixed. The...
Hi..so the Baxi combi at my folks' house has lost pressure twice over a period of a couple of weeks since they started using the central heating...
Dear All, I hope you might be able to point me in the right direction with an issue I have with a 3 year old Greenstar 30i boiler, last serviced...
Have just moved home and had a Worcester Bosch Greenstar Life Gr8300iw 30 C installed. It has a thermostat which I had turned down low overnight...
Deleted member 120897
