Discuss Worcester 40 CDi Conventional in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Danv44444
Hi Guys, I got called to look at the above boiler last week because the boiler would not stay ignited. The Flame kept fluctuating then eventually went to lockout. I phoned Worcester technical and tested evrything as they said but still couldnt find anything to fix it.
In the end the customer paid for worcster to come out and fix it for £250. The customer isnt very technical put said the worcester guy said it was something simple.
Have any of you guys ever come across this with worcesters before. I checked the gas valve, fan, Flue and cleaned the heat exchanger.
Any help for future reference would be appreicated
the problem you had sounds like it could be something to do with the co2 emissions and the gas valve not being set up correctly your minimum co2 should be set at 9.1% and maximum should be 9.7% if the boiler was making vibration noise when the flame was fluctuating this is most likely to be the problem.
Went to one of these at the weekend with a fan fault code. Managed to find local Parts Centre and bought new fan fitted it and got the same fault code. Customer decided to call in WB on monday who fitted a new fan and all was good. Turns out that the brand new fan I had bought was faulty! What chance have you got?
Just for future if you get 240V on the purple wire, its the fan! obviously the CDi throws a fault code also
Rang tech support when it didnt work and done some checks including your one, he said "if you had not just told me you have put a new fan on I would have said it was the fan" Neither of us expected a new fan to be faulty and he was right. Fair play to WB tech support they were working until 4pm on saturdays
modded ones have a purple spot sticker on them......some old stock (sat on shelves) ones dont
good to know thanks, had to replace a fan on a junior the other week at 10pm at night, no manual, no signal, tech line closed. Took a punt on a fan and plugged it in as I had heard they were fairly common and bingo, first time lucky! Nice to know of a way to test in future though!
Yep I agree, it's not the fan that fails BTW 99% of the time, it's the PCB built into the fan, which EBM who make them won't supply as a spare......
Reply to Worcester 40 CDi Conventional in the Plumbing Jobs | The Job-board area at PlumbersForums.net
