Discuss worcester 30cdi - heating but NO hot water in the Plumbing Jobs | The Job-board area at PlumbersForums.net
F
FFF
Afternoon all!
My Worcester boiler seems to be playing up and I am stumped. Pressure is fine - no errors - rads all ok
but no hot water in taps or shower. Water flow seems fine.
Any ideas?
thanks
just to note the pressure is ok at 2 and the blue light is on - temp is at a steady 55. Rather strangely the rads are still warm even though I have turned off the central heating...
You need a gas safe guy in to sort it mate , theres nothing you can do without breaking the rules
Is it a Combi or do you have a hot water cylinder?
Hi its a combi and I am wondering if the diverter valve is playing up - seems strange that the radiators go on when I call for hot water.
This plumbing forum will not provide advice to anybody with regards to boiler repairs or any other form of gas plumbing without you first providing us with your Gas Safe Registration number in a thread - for very obvious reasons. If you're not qualified to touch gas, you should stay well clear of trying to!
Reply to worcester 30cdi - heating but NO hot water in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Afternoon. I have an issue with no water flow from any of the hot taps in the house, I can't seem to find a solution to the issue. System is a...
Looking for any ideas to help. I've a Heatrae Sadia Hot Water tank, heated through Oil fired boiler (working fine). A week ago I reset the air...
The Water Board have just replaced the main water supply to our property. We have a ground floor combi boiler. The central heating system for the...
M
Hello, We’ve recently moved into a fairly old, fairly big detached house (i.e. fairly draughty, but not too bad by any means) with a fairly new...
MartinPod81
M
