Discuss Worcester 24 cdi rsf problem in the Gas Engineers Forum area at PlumbersForums.net
Hobo128
Hi all
I have a problem with a Worcester 24 CDI RSF.... The old worcester with the grey front..... the problem is low hot water pressure....I've had this before and have never managed to solve it.... checked the filter on the cold inlet and checked the plate heat exchanger too.... any ideas đź’ˇ
Check the flow and pressure out of the boiler might be a restriction tap side
Other than the diverter valve and plate it’s straight pipework
Reply to Worcester 24 cdi rsf problem in the Gas Engineers Forum area at PlumbersForums.net
PSxxxxxx
