Discuss Wonky Bath Panel - How can I fix/resolve for flooring? in the USA area at PlumbersForums.net
I recently moved into a new home and noticed that the bath panel is wonky earlier today. Is there a noticeable reason for this, it looks like those little plugs protrude quite far out, where as the panel wants to go in and therefore I have ended up with between those fixing points a wonky panel - any quick solution to this? I have flooring people coming tomorrow and don't want to mess them about too much - as it needs to be straight really - will they do it?
[automerge]1593026650[/automerge]
Attached another image for reference too.
Subscribed
Don`t understand "plugs", however have you tried removing the panel and looking behind it in that area? When refitting push the top under the lip of the bath last.
By "plugs" I mean the little button on the left of the first image, I imagine they are screws behind this that hold the panel in place?
Subscribed
Take panel off. Let flooring run under the bath an inch or two then refit the panel . You get a much better waterproofing detail this way.
Possibly you’ll have to trim a few mm from the bottom of the bath panel but it’s not a big job.
I think you should install bamboo in your flooring rather than other flooring. I had similar experience with wood or other flooring but when i installed bamboo flooring its going well now.
Reply to Wonky Bath Panel - How can I fix/resolve for flooring? in the USA area at PlumbersForums.net
