Discuss Will this be seen on sale survey? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
mutley racers
Subscribed
So went to look at some plumbing that needs doing at a house before sale and found this.
Needs to be put right hey as I am sure it won't pass. Surely BC didn't sign it off or probably doesn't know about it.
:D
Would get bc to check it over and to see if it's had a sign off
All depends on the level of survey being done, the cheap one to satisfy the lender can be a simple drive by and compare past sales in that road for valuation whilst a full blown survey is everything including the household electrics. Just sold mine and it was a drive by estimate with photos of the rooms inside, she was in and out in under 10 minutes.
It's pretty much like what you have in the pic but not very well designed. They have the drop at the upstream end directly over the channel and a steeper more sculptured benching. Usually found in a series of 2 or more on steep inclines to get the waste away on slopes as it would be too steep to lay the drain at that angle so it would be prone to backing up.
Hi. Thanks for clearing this up. So this is allowed? So I can just drop it a bit further down and slope it at an angle into the gulley internally. Looks like it when looking this up?
Bloody Hell,
You guy's haven't moved on since the 1800's with your sewer works.
I suppose the first convict plumber you sent here must have thought,
'Stuff those open drains, I'm making my mark and having everything sealed.
Bloody Hell,
No we do have sealed chambers now days. It is just that we still have building & therefore drainage systems older than when we kicked you out to go populated that far distant land you call home. :D:p
Anyway your drainage systems will always be different OZ cos it goes down in a different direction down under, don't it.
Reply to Will this be seen on sale survey? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
