Discuss Will my £30 McAlistair tile cutter cut 10mm porcelain tiles? in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
HI everyone. As per the title, can anyone advise whether snap tile cutters work on porcelain tiles or do I need a wet saw? Thanks
Depends on several things grade of porcelain tile what cuts you want to do small strips or intricate better with wet cutter.
Decent porcelain snap cutter eg rubi probably more money than you want to spend.
Do a test but if grade 4 and above I suspect maybe not
Reply to Will my £30 McAlistair tile cutter cut 10mm porcelain tiles? in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
My plumber fitted a shower, 2 of the walls are glass panels and one is a tile board (wedi board). He joint the wedi board pieces (3 pieces) close...
hi all i need some help and advice i am tiling around 2 shower pipe fittings. as the measurements were intricate i was practicing on off cuts...
Hello there, Relatively recently we had a new en-suite fitted (complete rip out of the old fittings, and old wall tiles and floor carpet). This...
Hi Everyone, Can anyone help? I have been searching but with no luck. I am trying to fit a Duravit shower trap which has a 50mm outside...
Hi, does anyone have any advice on fitting a natural stone resin bath and shower trays over wet UFH. I have been advised that the bath could be...
