Discuss Will it cause a problem if your gas pipe is too big? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
coldboiler
Does it matter if the gas pipe from the meter to a combi gas boiler is too big ie.28mm?
What harm will it do?
Let your gsr worry about it.
The boiler manufacturer has said that it will not matter if the pipe is too big ie.28mm.
In fact they said the bigger the better especially if other appliances (gas fire and cooker) are also connected.
However I have had conflicting opinions from installers.
no Iam finding a lot of combis need that extra size now, running a lot in 28mm
As said before. Let your gsr worry about it. He should size it properly to take into account the other appliances and still save you money.
No point running 28mm if your boiler is close to the meter!
Thread closed.
Reply to Will it cause a problem if your gas pipe is too big? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Had conventional boiler and tanks removed last year and new combi fitted and just recently had it serviced but the guy who did it has given me a gas warning notice for at risk as the outside wall meter box has been drilled through for the gas pipe to go horizontal straight to the boiler. The...
Hi folks, i've just moved into a property last month and begun to take note of things that may need attention. One of which is the feed to a 35kw system boiler appears to be in 22mm flexible steel pipe (tractpipe, or teslaflex or w/e). Distance from the meter is only 4m-5m or so, and I assume...
British Gas servicing the above boiler ramped up the boiler to maximum in the installer menu to do flue gas analysis. They also measured the working gas pressure on the gas valve test nipple. This fell to 8mbar on maximum and 17mbar on high setting. They then removed the isolation valve under...
Hi, moved into a home a year ago with what is probably an old heating system. There is a gas boiler linking to radiator central heating, and a water tank. Energy company charged an enormous amount for gas last winter (admittedly I hadn't taken regular meter readings so was unaware until a huge...
I have been facing central heating low pressure on unvented hot water RM Cylinders but can't see any leak on the PRV, expansion vessels and plasterboard celling. I have got unvented pressurized RM Cylinders hot water system with 27KW Worchester gas boiler with expansion vessels . When...
losing pressure
L
