Discuss Will all electric showers work with a combi boiler.Ash in the USA area at PlumbersForums.net
As above an electric shower is seperate. If you have a pumped shower, that is seperate pump away from shower then pipework needs modifying, if it's a power shower (pump inside shower case) or digital then no.
Reply to Will all electric showers work with a combi boiler.Ash in the USA area at PlumbersForums.net
Recently had a Viessmann Vitodens combi boiler installed, quite often when the adjacent cold mixer tap is opened the boiler starts for a few...
Can anyone remember the Mira mixer shower that would work down to a really low pressure on a vented hot water system without a shower pump?
Pipes for thermostat shower have been fitted at different heights. Any way of rectifying without ripping all tiles. So for clarity 15mm pipes...
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I...
