Discuss wickes combi 82 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
buckley plumb
went to this tonight seems like aps fault but can any one tell me one of the aps pipes goes fro the fan to a tee ontotp of the boiler then onto the aps .the t part is open ended is this correct or should it have a cap
Ya should have a cap if its sticks out the top. try it with something blocking it bet it will fire and work properly.
Probably got knocked off if they store stuff above it.
cheers mate it did work when I plugged it with my finger - but they said no one has ever been up ontop of the boiler .boiler fired when I removed front cover will have to think what I can plug it with as I doudt I will get one from parts supplier
It should have a black cap ontop of it. Like a cap on a worcester fan test point. It's a flue sample point. If you take it off and run the boiler, it will go straight to lock out.
Im sure wickes boilers are re badged halsteads
I'll probably get shot down for this but as a temp blutack..Had to do it before.
It would definitely work :)
But, I personally woukdnt do it, as far as that customer is aware the boiler is working and they might not let you in to put things right, then you've for a potentially ID situation on your hands that you've caused :(
Thats why when i do the blutack trick i grow a beard beforehand....:)
found out how cap went missing the cat sits on the boiler they think it may have ate it lol
Was cap original problem Buckley ?
was called to it not working hot water and htg stopped - removed cover and boiler fired - checked aps and tubes and noticed the tee bit and no cap put finger over tee and boiler worked so assume that was it - fitted a piece of aps tube and doubled it over with cable tie for now .trying to source cap
Not sure if it applies but a dust cap fits some of em. Or even a domed nut like some ideals have.
Reply to wickes combi 82 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Recently had a Viessmann Vitodens combi boiler installed, quite often when the adjacent cold mixer tap is opened the boiler starts for a few...
Sonya K
Hi guys....we have an old Astracast sink top....I think its a composite sink....has a big single bowl. My wife thinks it looks scruffy....looks...
