Discuss Where will I find my drain valve on F&E system? in the USA area at PlumbersForums.net
I need to drain my F & E heating system so I can replace some TRV's and radiators, however, I am struggling to locate a drain valve downstairs (inside or outside) to connect a hosepipe to. The only valve I can see on my downstairs radiators is like the one shown in the picture.
Can anyone advise where I need to look?
Yep that’s one drain like in the picture
anything above the boiler ?
if not looks like you will need to remove a rad and then drain from the valves
OK. Thanks.
There appears to be a drain valve on the cold water feed into my downstairs toilet system. I am assuming this will have nothing to do with the heating system?
Correct nothing to do with the heating systems
Reply to Where will I find my drain valve on F&E system? in the USA area at PlumbersForums.net
Hi Does anyone recognise the make/brand of the radiator valve. It leaks when closed and Iam hoping I can replace a seal etc?
Sonya K
PSxxxxxx
