Discuss When the customer says in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Scott_D
Subscribed
when the customer says I have OCD I will hang the radiators.
She then calls to say it is ready for the rads to be connected and get the heat on
Rustic look ?
Scondary title to this should read .
'when the plumber says'
Sorry due to the brackets being askew I now have to alter my pipework to fit the 'askew ' column rad .
This will be classed as an extra which will be alot .
Reply to When the customer says in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, Later this year I am going away for a 2 week holiday and as the weather will be warm there is no need for the heating to be on and arguably no need for me to needlessly heat hot water. My intention was to turn the boiler off along with the mains water when going away. Now, I have heard...
Hi Does anyone recognise the make/brand of the radiator valve. It leaks when closed and Iam hoping I can replace a seal etc?
