Discuss What's the nut on top of a gas supply bayonet fixing used for? in the Oil and Solid Fuel Forum area at PlumbersForums.net
I have a redundant gas cooker supply to cap, but wondered what the nut on the top of the gas supply bayonet fitting is used for?
Picture ?
Presumably to allow the valve components to be assembled inside (during manufacture) 🤔
If you're talking about this sort of thing:
I expect it will be how they assembled the fitting.
In theory they are designed to be disconnected and gas tight. Realistically though I would get it capped. IT IS NOT SOMETHING A NON GAS SAFE ENGINEER CAN DO.
Guidance Note 65 to regulation 6(3) of GSIUR states:
“When an appliance is disconnected and open-ended pipework is left, the pipework should always be left sealed with an appropriate fitting. A self-sealing coupling, e.g. on a cooker connection, does not need to be capped-off, except where there is a significant risk of interference (such as by a child). However, it should be checked that any disconnected coupling is not leaking gas (see paragraph 68), and any wall- mounted connector has been installed in the downward mounted position to prevent dirt or grit getting into the self-closing seal.”
Reply to What's the nut on top of a gas supply bayonet fixing used for? in the Oil and Solid Fuel Forum area at PlumbersForums.net
Hi, I’m having a gas cooker pipe capped off. The GS registered plumber/ fitter, has told me that to do this, he’ll also have to service the combi...
Im fitting a kitchen in my own house . When removing the gas oven on a bayonet fitting and turned the gas hob off and removed a four burner gas...
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
I am fitting a thermostatic shower control. The flow knob fitting has a threaded section - 27mm OD - and it would be helpful to get a nut to go...
I needed to replace the braided water pipe for the hot tap as I was putting everything back together; I placed the female end into the copper pipe...
2K
