Discuss what type of seal is this? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
I am trying to create a water tight seal on this joint (in the attached photo) on the side entry fill valve.
The copper pipe seems to have a flange and a copper coloured seal of some kind.
I thought the "copper coloured seal" was a compressed olive but now I think it may be some kind of washer or o ring.
Can someone experienced say what the old seal is? it seems too thin to be an olive.
There seems to bit a chunk of your tap connector (flange as you call it) which may prevent it sealing correctly. Also, be careful with the plastic thread on the Torbeck filling valve.
Thanks everyone.
The dripping has completely stopped and I'm over the moon.
Yes the "seal" was indeed a fibre washer (1/2"). (amazing they expand when they get wet so only use once)
Initially I actually thought the seal was an olive from a compression joint :)
It was hard to find a float valve that is low pressure and brass but I eventually got one and it has worked great. It is part 1 so might not please plumbers but it was my only option.
Why are all the float valves in the shops plastic?
The brass shank has led to another (much smaller) problem but I think I should put that in a new post.
https://www.NoLinkingToThis/p/flomasta-brass-part-2-float-valve-1-2-/358fy
What’s misleading with that is, Screwfix state for high/mains pressure, but we know as plumbers that we can change the orifice for a low pressure type 😉
I did look at the high pressure valve in @ShaunCorbs post. B&Q have the same item (at 50% extra cost) but the B&Q online add says low pressure so I went to look at it. The packaging made no statement about the pressure so I got it out of the bag because I wanted to be certain.
It was high pressure with no low pressure jet. You can blow through the back with your lungs and tell which it is, also the jet diameter is noticeably different.
All the plastic float valves I saw have a white high pressure jet fitted and a red low pressure jet in the packaging. None of the brass valves have 2 jets. I looked pretty hard.
I got the low pressure from toolstation.
I can't post the link, you would see they do high and low pressure versions, not 1 version with 2 jets.
Will that fit the "Flo masta Brass Part 2 Float Valve 1/2" (3 5 8 F Y)"? (the original item you posted)
I haven't opened any valves up, if they all have the same jet inside then I wish I had known that 2 weeks ago.
Reply to what type of seal is this? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi I'm going to be fitting a tap like this one: And just wanted to check that this is the correct part for connecting to 15mm copper pipe...
Forgive my ignorance, with this basic question, but I seem to be struggling to both understand, search for, and source, the appropriate washer...
Hi, I am probably being unduly paranoid here but I noticed under our kitchen sink that there is some corrosion evident on a small section of...
I have fitted this brass float valve to my toilet cistern. Obviously the inlet is the same level as the overflow pipe so it needs to be water...
