DIYBlues
Hi Guys
I have to install two showers both thermostatically controlled and each specifies a minimum of 0.5bars of pressure. The two new shower heads also requires a minimum of 0.5bars. Do you have to add each of the requirements up totaling 2.0bars or is 0.5 the minimum of the whole system needs?
It is probable that both showers will be used at the same time.
I don’t want to use more than say 10 liters per minute per shower as on testing my current system we used just under 5 liters which has always given a reasonable shower but I guess this could be improved.
So my question is what size/type of pump should I use and do you recommend one?
Regards
Simon.
Regards
Simon.
