E
emailalantaylor
Can someone give me some advice please as to the correct size radiator to order .
I want to install in the bathroom, an LST double radiator in place of a very old chrome bar towel rail which gives off very little heat into the bathroom. The heat comes from water out of the central heating system.
At present there are two copper water feed pipes coming out of the wall at a low level, horizontal to the floor, couple of cm above floor level. They are 600cm apart. What needs to be done is disconnect the old chrome radiator and install the new LST rad.
I am thinking in terms of a wall mounted Radiator unless advised otherwise. I don't know if I order one 600cm wide or less than that to allow for the need for Right angle elbows and control valves? It all depends I think on the entry points into the new radiator.
Has anyone any suggestions as to which LST rad size I should order. It can be up to about 800cm high , but its the width that is causing me a headache- how wide so that we use the two pipes available, 600 cm apart.
Really helpful would be to point me to an actual rad to buy for the job..
