Discuss What reducer do I need? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
And a 35 mm coupling/ adapter if it's imperial
Not sure why I need a 35mm to 35mm or 35mm to 1 and qrtr
Because the reducer you have is a fitting reducer so it's the same dia as the 35mm pipe so you need a coupling
TBH it sounds like you might need the help of a heating engy
Yep that will do also
Reply to What reducer do I need? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
